Can I do this?
9 May 2015
Midlothian
I want to baton plasterboard an external facing internal wall and then gypsum wet plaster the adjoining internal facing internal wall.
Can this be done? Any potential problems where the gypsum meets plasterboard.
Probably best to attach batons, then wet plaster adjoining wall and then after this has dried attach the plasterboard??
Any other advice on best way to di this would be appreciated.
No problems if done properly, differential movement which causes the join to crack is what you try and avoid.
Strap and sheet the wall first then scrim tape the corner before wet plastering.
