I currently have a cooker duct connected directly 1 meter away from the hood into the outside wall. using 205x 60 ducting. The problem is my neighbours complain that the cooking odour comes into their open windows and lingers in their house!
I have looked at redirecting it in the ceiling to to another side of the kitchen to an outside wall but there is a cross joist in the way and i can't cut through it.
The other alternative is to use ultra thin ducting (the 225 x 29) and duct it directly up through the ceiling, up the wall the corridor and into my attic where there is the remains of an old chimney which the duct will go into. the ducting will directly vertical into the base of this chimney in the attic.
The length of this will be about 4.5 meters. the fact that it is a straight line will that help the ducting? do you think the fan will have enough power to blow it upwards? will the odour emanating from the top of the fan, simply go the rest of the way up out of the chimney (another meter)
failing that is there something i can attach outside my current one that can pacify my neighbour??
