I have an old inspection chamber on my drive, that I would like to fill in.
It's poorly constructed, single skin, standard bricks, a single inlet and outlet (just one pipe running through). The opening of the inspection chamber is larger than it should be if I want to replace the lid, 49CM x 62CM.
It takes the water from my garage and house roof (not human waste).
I have been advised to repair making the opening smaller with concrete lintels. However, now I'm wondering do I need the chamber at all, it doesn't seem to serve any purpose and I don't want my car to fall down the hole.
The new gullys I have fitted can be used to rod out, although am not sure about whether they can clear the property boundary pipes Approx. 20 meters long.
Could I not cut down some Flowplast pipe to cap off the top of the halfpipe, glue with Sticks like #### or similar, backfill with concrete up to the sloping concrete of the original chamber and then backfill and finish off?
Or perhaps there's a better method to protect the pipe and fill in the chamber?
Or perhaps filling it in is a no-no, if so please let me know?
