Hi
I am about to upgrade my gas boiler & HW cylinder. They are located in a dry cellar, which (because it's below ground level) has no internal drainage facility.
An unvented HW cylinder has been suggested as a replacement. However, I notice that these require a T&P relief valve which must be fitted with a gravity fed outlet through a 'Tundish'. I can't drain off this by gravity in the cellar - it means going uphill!
- Does anyone know if there is a way round this, keeping the same cellar location?
- I appreciate I'll need a condensate removal pump for the boiler as well. Is a similar arrangement feasible (and legal) for the Tundish outlet?
The current system is a traditional indirect vented one, with cold water storage cistern and, boiler feed and expansion cistern in the loft. The roof is a shallow pitch, so I pump both cold and hot water upstairs to achieve a good strong flow to bath, basins and showers. Changing to a new 'System Boiler' is not really a problem.
Perhaps I should just stick to an old fashioned vented cylinder, but the newer ones do seem to be a much higher spec & performance. However, another factor is that the metal skinned ones all have a single 22mm top outlet, and no option for a Surrey/Warix Flange (needed for high flow rate take-off.
- Am I scuppered?
Any ideas would be gratefully received. Thanks.
adrianhar
- Am I scuppered?
adrianhar
