Old big house with two combi boilers - one for upstairs, one for downstairs.
The system for downstairs has one rad in the bathroom upstairs. So highest point on the circuit.
I had to fit a 2 new rads downstairs and whilst the system was drained decided to replace the one in the bathroom that was showing some rust on the bottom seam. I took it off only to realise the valve fittings/tails were 3/4 and I couldn't remove them (no flats). Probably damaged them trying to remove non existent olives. Gave up and fitted blanking caps.
Only managed it today after Googling (never seen them before) and improvising with a spline key and ratchet - easy. In the meantime I had to refill the system and get the heating on.
Today bought 15mm tails and new TRV
Now the question!! As the rad/pipes are at the highest point on the circuit, can I let the pressure out of the system either at the boiler or at a rad and will the water stay in the pipes allowing me to fit new rad, tails and TRV or is it another drain down? Is there such a thing as a partial drain down?
Sorry this is so convoluted but I hope I have explained myself well enough.
Many thanks - Mike
Many thanks - Mike
