Hi, I am about to install a new digital shower (Mira magna UV pumped)
http://www.mirashowers.co.uk/onlinecatalog/pdf/magna_uv_bir_fittings_iug.pdf
with digital mixer pump (DM Pumped) http://www.mirashowers.co.uk/onlinecatalog/pdf/p4581_1.pdf
where my old thermostatic mixer one was, using the same hot and cold feed to the new water delivery system, just introducing a digital mixer pump between them.
The mixer pump is in the loft, just above the shower.
My question is, would I be able to tee off the hot and cold feed to supply a bath in the next room.
The pipes from the tee would have to go to the wall of the loft, about 5 mtrs, then through the ceiling and down the wall of the room with the bath 2.7mtrs and then about 2 mtrs to connect to the bath.
I am assuming that I wouldn't be able to use the shower while running a bath and vice versa, but would this otherwise be ok?
It will save me a lot of work if it will.
