Can I get replacement LED Buld for Lap Security Light?
20 Dec 2012
I have a LAP brand Security light I think these are the ones sold by Screwfix.
The LED Bulb is about to go. Does anyone know if I can get replacement bulbs or do I have to replace the whole unit?
I don't see anything about bulbs in the instructions. The part numbers on the instructions is L3292S-B (122CC)
and L3292S-W (475FY)
You have to replace the whole unit.
Interestingly, they've also been the subject of a product safety notice.
Apparently they are known to fill up with water!
  • product_safety_LAP_floodlights.pdf
LAP products have one positive feature, they are cheap.
Maybe, but I've had no concerns about them with the loads I've used. To date only 2 premature failures: Pull switch in rental bathroom - but who knows how heavy handed the tenant is and one floodlight of three which ran 24/365 which failed after a few months and replaced under warranty.
I've had to replace a number with physical damage but that was probably the reason I started using cheaper products in the first pace.
Lap led floodlights are best avoided
Replace it with a unit which has a 3 year warranty
For what it's worth as of 4 months ago all 3 of these are still running 24/365, I did the replacement of the failed unit in April 20.
... one floodlight of three which ran 24/365 which failed after a few months and replaced under warranty.
Thanks, that is what I thought. I have had no issues with water inside! as far as I know. I will look when I replace it.
I have had it two and a bit years I think. Its on the back door step so gets all weathers. :)
Lap led floodlights are best avoided ... Replace it with a unit which has a 3 year warranty
Seemingly no need - the LAP ones appear to come with the duration of warranty you want ...
