Can I improve my DHW Flow rate Vaillant 824
13 Feb 2009
Isle of Wight
Does anyone know it is possible to improve the flow rate on a ECOtec824. Can I possibly loose some top end temperature in gain for higher flow rate? Is there some kind of flow restrictor in the cold water supply, if so could I remove this and refit a higher flow rate restrictor on the incoming cold?
Cheers
Why not blend the hot water to give higher flow rate?
Modification will end up in tears.
