I've got a flat roof porch that was single glazed full height as originally built, a fixed pane at the lower half, followed by a horizontal wooden bar, followed by another pane. Quite a few years ago the lower pane was replaced by a wood panel. The window frame is 3.5cm thick on the inside, 2cm thick on the outside, and the panel that was inserted (from paint on the outside to paper on thie inside) looks to be the same thickness, so 5.5cm of wood (and maybe some insulation wool filler?) separating the inside from outside.
The porch is covered by a flat roof that extends over the garage so the distance between porch ceiling and outside is probably very small. And probably not insulated.
Is all of this likely to be a significant cause of heat loss in the house? I'm assuming yes, but would like some advice please.
I'm intending to get a replacement DG window. When this is done is there anything I could or should do to improve insulation? Maybe some sort of pre-insulated panel? Or replacing the panelled area with brickwork? The door (which is at right angles to the window) could be moved up to 25cm, so 25cm would be about the tickness of wall that could be built 'on the inside'. To this I would guess the porch could be extended 'out' at the base by 5cm or so, to give a max wall thickness of 30cm. I can't think of any way to increase the space available in the over-ceiling space in order to fit insulation there.
Anyway, i appreicate any advice.
