Can I insulate between original floorboards and engineered
25 Sep 2012
Newcastle upon Tyne
Ok here goes... I have a Victorian wood floor, joists on brick courses. Not enough space for crawling , but ventilation seems ok. Then floorboards, a bit tatty, has been cut about for central heating electrics etc. it's cold so I want to insulate.
Should I lay insulation, ( what type )
Then secret screw on an engineered floor ( with room for expansion ) . I want to screw it down because the floor is not that level in places.
Many thanks, all advice greatly appreciated
You mean lay the insulation onto the floorboards, rather than pull them up and go in-between the joists?
Don't see why not if you don't mind a step.
But the top floor would be better floated, maybe lay down some plywood first to level out the floor, then some rigid insulation.
I am considering pulling the floor up, it will be more disruptive but a better finish I think...... But if I go for floating I'll stick some ply down like you say , hopefully it'll be less boingy
