Hi All,
I'm a new user, but I think this is the right place for my question:-
I live in an old Victorian Building which has a large wet cellar underneath the the living room. The cellar has a gully around the edge of the cellar floor which feeds into a drain in one of the corners. However its fair to say the cellar floor is still fairly damp (Particularly if there is a lot of rain).
There are at least 2 ventilation bricks abd these are below the ceiling of the cellar.
The living room floor, is pitch pine floorboards on woodjoists, which in turn appear to be above concrete joists.
My problem is the cold from the cellar seeps through the living room floor and makes the room cold (particular on the feet).
What I want to know, is whether I can use insulating boards on the cellar ceiling (Celotex/Kingspan or something else). Basically attach the boards to the concrete joists. Should I put the boards between the joists, or can I attach them to the bottom. If I attach to the bottom of the joists can I fill the gaps above with rock wool, or does this need to be left for ventilation?
Thanks in advance
Joe
Thanks in advance
Joe
