I am planning to lay a laminate floor to finish off garage conversion which has just a concrete floor at the moment - the floor itself is level but I need to insulate it according to building regs.
I am planning to use 50mm polystyrene sheets as insulation but can I then just lay laminate directly on top of this or will I need some chipboard over the polystyrene and then put the laminate on top of that?
Jase
Jase
