I have a Bosch POF 1200 AE router which I'd like to mount to a simple home-made router table, with a simple pivoting fence. The manual doesn't say anything about mounting the router to a router table and does not include any fixings for doing so. There are three holes in the base plate (and the plastic plate which mounts onto the base plate) as I've attempted to photograph. Can I mount the router via these holes?
One of the holes on the other side is obstructed by a plastic cover which can be removed.
Here is my design for a table:
What pieces do I need to make the fulcrum (red) for the pivoting fence?
Edit: I forgot to indicate that this table is intended to be used in a 'workmate'. Also, I don't think that the removable plate, common in router table designs, is necessary, given the anticipated infrequency of use.
