My meter, isolator & old fusebox + extra fused connections for a ring into an extension, heating & shower (no space in main fusebox) are all together on the inside of a main, originally external solid wall.
I am looking to open this wall (exactly where all the above is) into the existing extension.
The wall is about 13inches thick and wider than the widest part of all the above (including the wooden board the meter and apparatus is mounted on)
The easiest solution seems to be to just move back and turn the whole lot through 90degrees to the left and sink into a resess in the newly formed side of the "hole" into the extension, this could then be neatly boxed and have a door flush to the wall for access.
The main supply cable drops in from above and is loose, in that I am in an end terrace and have meters of supply cable laying spare in the loft that can be pulled easily further down as needed.
I envisage that turning 90degrees will mean needing to also drop about 12inches so that all the wiring coming up to the box from the floor boards to the fusebox will have enough slack to reach the new location.
There would be no need to disconnect any cable or seal at all and the only wiring change required would be a slight re-route to the incoming cabled from below and the pull through of 12inches or so more supply cable from the loft.
So - is this permissible to do myself??
I can't see anything at all that the supply company or an electrician would need to do providing nothing was dislodged and no cable became loose from being moved.
I do intend to put in a new CU unit at some stage to tidy everything up a bit, but that's possibly for another time.
If this seems ok, is there a good way to explain this procedure (or even a need to) on the building regulations form I will be putting in to cover the opening of the wall itself?
Any advise would be gratefully received.
Many thanks,
Phil
Many thanks,
Phil
