Hi, been pondering this for a while and need some help please.
We are currently running a pathetic electric shower and want to replace it with a monsoon type mixer running directly from the hot water tank. We also want to install a similar shower in the the en-suite.
We've been told that as an absolute minimum we'd need to install a new pump to get hot water to the showers with enough pressure. Also, we've been told that if we want to run two such showers then a larger cylinder might be required otherwise we'd run out of hot water quite quickly. All good so far.
So, as we'll probably need to replace to the cylinder anyway I want to look into the possibility of moving to an unvented system so that we can remove the header tank in the loft room. A few questions in this regard :-
Thank you for your time.
- Our cold water feed into the house is only 15mm and comes in at about 14 litres per min. Is this suitable for an unvented system ?
- Can an unvented system supply enough hot water to the two showers without the need for a dedicated pump ? or will this still be needed ?
