Can I paint onto acrylic filler?
1 Aug 2011
Bristol
Hello,
I am planning to paint bare (unvarnished) floorboards using floor paint, but there are some cracks that need filling first.
I know there is a lot of advice out there on the best way to fill gaps between floorboards, but I think I am going to go for a flexible acrylic filler. But what I need to know is will I be able to paint over this with the floor paint or will this give me problems later on? Would using a floor primer paint help if this is the case?
If it is a problem, would I be ok to paint without filling the gaps? Draught is not too much of a problem in this room so filling the gaps would be mainly for aesthetics...
Cheers
T.
An acrylic frame sealant type thing is fine - used it on my bathroom floor a couple of years ago, Still perfect. Don't try to hide the lines completely or it will look like a sheet of plywood.
Many thanks
So just leave a shallow furrow along each gap?
I was planning to just run a wet finger between each floorboard to push the sealant down and in.
Yeah, what you propose is fine.
As you say use your finger and a damp cloth to remove the excess off the sides if any.
Make sure you leave enough drying time before the application of paint.
