easy guys, i normally get a pro in but i only need to touch up some paint on my window frames, a little part is a bit damp, can i apply undercoat over this?
cant let it dry out as its outside.
The only other option is to use a heat gun to try and dry it out and dab some primer on it. Might just last the winter then and you can do it properly in the spring.
