I've removed a cupboard exposing a bit of a hole in the ceiling where a pipe comes down. Once that pipe is boxed in I'm going to be left with a hole about 2 inches square in a not square shape.
What's the best way to repair it? Cut it square with a new piece of plasterboard? Or leave it and put a mesh patch on it? Then do I need to buy specialist plaster of can I put a thin layer of easifill over it, then a wetter layer and 'stipple it' with a brush/sponge etc.
It doesn't need to be perfect at all. It's in the corner of the room that's hardly used and there is a previous patch where there's been presumably a crack. It just really needs to have the hole filled. It doesn't matter if it matches.
