Hi all,
I am hoping to install colour changing LED strips under my kitchen cabinets at floor level. At worktop level there is an FCU connected to the 32a ring main which currently has old mini fluoro tubes connected to it under the upper cabinets. It will be relatively trivial to extend this circuit behind the plasteroard and down to floor level but there is no space down there to put the LED driver. However, if I put the driver under the top cabinets then I am concerned that the long run of cable down behnd the wall at 12 volts will be too far and I will get voltage drop.
My plan was to remove the kickboard and conceal the wiring under the cabinets - and I am now wondering if I could install the transformer down there?
The cabinets are MDF and sit about 4 inches above the floor. So if I installed the LED driver under there then I would effectively be running it inside an MDF 'cupboard' with a concrete floor that is about 120 x 60 x 10cm high. It could be accessed for repair/replacement by removing the kickboard but is this a no-no due to the heat building up?
My calculations indicate I will need a 60w driver on each side of the kitchen. I was planning to buy the 'inline' transformer that just wires straight into the circuit but an alternative would be to buy one of the brick-type transformers with a plug and put a hole in the side of the cabinet to plug it in - but the brick part that gets warm would still need to be under the cabinets. Would this make any difference?
Thanks in advance for any guidance or specific regs regarding this
