Can I put both oven and hob onto a 32A supply
8 Sep 2008
Wiltshire
I am going to update my kitchen currently and want to have a built in oven and electric hob. Ideally a double oven. The oven does have a cooker point that is linked to the consumer unit with a 32A RCD.
Can i connect both the oven and the hob to this one supply or do I need another supply put in, or look at other options?
Adam
it depends on the rating of the oven you pick, you will be limited to approx 7KW with a 32A supply.
gas hobs are better, and do not need a huge electric supply
