Can I put ceramic tiles on floating floor?
20 Feb 2010
Liverpool
Hi I'm new to this forum and need some help.
Basically I have just had the most awful cowboy builders in and they have ruined my bathroom. Since then the bathroom has been stripped and is now a shell.
The old builders told me that I shouldn't put ceramic tyles on a floating floor. Is this true?
If I can what is the best way to prepare the floor to take the tiles?
Thank you.
What do you mean by a floating floor?floor brds on joists?
I would inerprite floating floor as laminate where the flooring just lays on the floor with no fixings.
Hi
It is chipboard on top of joists and the chipboard has been screwed or nailed down so it is fixed. Apparently this is called a floating floor!
You can tile over a “floating floor” but I would not advise tiling onto chip (crap) board; you could overboard with 12mm WBP or tile backer boards but I would take it up & replace with 18-25mm WBP ply, depending on the size, pitch & span of your joists. Seal the back & sides of the ply with an SBR sealer & fix with screws down into the joists ever 200mm; any joins in the ply must either run down the centre line of a joist or be supported with noggins; sometimes these aren’t really necessary around the edge of the room if the floor is unlikely to be subject to loading.
