- Joined
- 11 Jul 2007
- Messages
- 440
- Reaction score
- 3
- Country
I need to raise a new internal steel in the house (which will take attic floor).
By 35mm (don't ask why we didn't instal at the correct height)
1) I've been thinking of taking out the padstones and resetting at the correct height (bit of a pain)
2) Packing with a bit/bits of steel to the correct height
3) Packing with another cut of padstone
In my thinking 3) should be ok as the padstone spreads the weight down and onto the bricks, so cutting another with the same dimensions and either placing, bolting of cementing (reduce height of padstone accordingly) should be an issue.
Was thinking that I may not need to do any fixing as there shouldn't be any movement in the steel and padstones.
What do you think?
Cheers
What do you think?
Cheers
