Can I re-lay my engineered wood floor?
14 Sep 2014
First time post, folks, so go easy on me!
I need to pull up an existing wood floor (engineered wood) that covers two rooms and a hallway in our Victorian terrace flat to gain access to the floorboards and pipes underneath. I'll also be reorganising the partition walls to re-size the two rooms.
I am trying to decide if I can relay the existing flooring when the new studs are in, relaying the flooring pieces like a jigsaw, whether I will just need to lay a new lot. For example, I don't know if the flooring is bonded to the subfloor or not: would it normally? Or would it just unlock and come out like pieces of a jigsaw that can be re-used?
Advice welcome on this please.
It's likely Glued at the joints or/and pinned to the subfloor/ply preperation.
Unless you are very lucky and it's a click glueless system, budget for a new floor.
Update: we need a new floor. The planks were T&G, glued down on the side with the short tounge (though not the long tounge), which meant nearly all the planks have a snapped short side tounge now.
It sounds like you're doing a serious chunk of work in both rooms anyway, but this is exactly why I pushed my installer to add thresholds between rooms even though the flooring was identical. He was surprisingly reluctant, but you barely notice them and I'd hate to have to pull up half the ground floor just because of an issue in one room.
