I have a Flymo Vision Compact 380 hover mower.
Last time I tried to use it nothing happened when I held the grip of the power switch in place.
I have now looked at the state of the mower in a little more detail. When the power switch is operated 240, ac volts are present at the terminals of the motor unit. But there is no movement or sound from the motor.
Anything sensible I can do to try to repair the mower? Or should I just take it to the local Tidy Tip and then look for a replacement?
Thank you.
Thank you.
