Hi there,
I have read just about every thread regarding this Baxi boiler and have a reasonable idea as to what is wrong, I am just not sure exactly how to solve the problem!! The pressure keeps dropping in the central heating system so I have to add some water every day. When I looked outside there is a steady drip of water from the "overflow". I then checked the pressure valve at the back of the boiler and it was wet. My theory therefore is that the expansion tank is full of water and that it is just "overflowing" when the boiler is running.
I have good access to the valve at the back and can fit a pump onto it but of course I can't repressurize it because it is full of water. My question is therefore very simple. I know that there is a drain valve on the bottom right of the boiler. Is there a way that I can drain the water out of the boiler without having to drain all the water out of the heating system etc and then having to completely recommission the boiler.
Thanks in advance for any advice that is offered.
