W
watchit
Hello all,
First of all I would just like to comment on a wonderfully stocked website with a miriad of helpful hints and tips. I think you all must just love a really juicy problem!!?
I'm not sure if this is one of those, but here goes:
I'm currently about to start the install of a completely new system. New boiler, tank, rads on the upstairs floor and living room, the rest of the downstairs is good and will be fed by it's own feed and return.
I'm zoning 4 areas.
Living room, main bedroom, guest bedroom and rest of house, all of course with their own respective room stats.
The feed for the living room rad will drop down from the first floor.
As you can see in the pic, I hope I've covered it. The cold feed to the rear bathroom might be altered slightly, not sure yet.
The question is this:
From studying the proposed install, I have noticed that there is a strong possibilty of reverse circulation through the rest of the house return when the zones are being fed. 5 2way valves are being used, 4 for the zones and one for the HW.
In the diagram, you can see that I have put X's with an arrow next to them to indicate two of the places that I was going to include non-return valves....but now I'm thinking again...
Can I just completely reverse what I have planned, (except of course for the HW feed and return) and have the whole system's zones valves operating soley on the returns to the boiler form the respective zones?
In other words, apart from the hot and cold tap water, is it possible to change the red lines to blue ones and vice versa and just have the flow travelling the opposite way? would that solve the reverse circulation problem?
Any help with this would be massively appreciated as I've never tackled plumbing before so I've spent the last six months researching like crazy and my confidence levels are high. Building regs et al... Even my soldering seems to be coming on a treat.
Thanks in advance, if you wouldn't mind.
I'm zoning 4 areas.
New System 1.
- watchit
- 2
