Just when I thought it was over another challenge appears, help please! I have 6mm cable running from my consumer unit, using a 30amp fuse to my control unit in the kitchen( was there Before). My new hob appliance uses 6.2kw. My existing 6mm cable will not fit, Manufacturer say's if you can't get it to fit use 4mm. Can I run 4mm cable from a 6mm fed large on/off double pole Control unit.
On The hob where the cable goes it says (3 x 1.5 Max) what size cable is this????
Thank you...
Kumbi
Thank you...
Kumbi
