Can I screw to chalk wall?
11 Jun 2016
I've concreted a 3x3 timber post into the ground next to a chalk wall to use as a gate post. The gate is 1000mm x 2000mm ; I'm worried that once I hang the gate the post will flex.
I want to use a galvanised bracket to brace the post against the chalk wall.
Can I drill the chalk and plug it or use concrete screws? Any advice welcome.
Thanks in advance
Rob
The answer I found is yes. Madonary bit and rawl plugs very successful.
