Can I seal a wall+not render it before fixing Thermal board
3 Jun 2008
London
I have conflicting needs: I have a small bedroom with a relatively large-ish cold outside wall and I want to improve its thermal efficiency without making the room much smaller than it is now. I have hacked off the old plaster on the wall so I have bare brickwork there.
I understand that one possibility is to apply a skim coat of mortar (er actually get a bloke in to do that), then apply 2 coats of Bitumen-Latex emulsion, then fix the thermal board either using furring strips or apply the thermal-plaster board directly using an applicator gun and golf-ball sized blobs of special adhesive.
May I ask:
(1)
Is there an easy way - do I have to apply mortar or can I just use some kind of "paint on sealant" on the bare brickwork before using the blob+nailable-plug board installation process?
(2)
I guess "tape+fill" actually means "fill+tape" i.e. fill in the gaps between the boards with sealant then tape over it before emplyong a plasterer to skim the finished job ?
(3)
Using the glue-blob method sounds easier than using furring strips - why would one use furring strips then ?
Any tips much appreciated.
Thank you - sorry to be thick but if I use Black Jack can I put up thermal-plaster board using battens on teh brickwork without rendering or plastering a skim coat ?
yep we are at the mo on site in a refurb black jack batton it board it tape and joint it sorted
now thats just a start on the black jack so we can start on the screeding its over a flag stone wall that will be gyp studed ie metel stud work the boarded and finished
get it on the all nice and proper coat it good let it dry and there you go sorted
same as plastering and drylining coat the wall then batton it board it trust me thats how its done m8
is that a drain cover in the second pic to the right of the tin of backjack? if it is your screeding over it?
