I am trying to work out the best way of connecting some low voltage downlighters to the mains for the kitchen cupboards, i have a fused switch which in on the main ring ( 1 wire in and 1 out ) ready to be connected to a hob fan and was wondering whether i can still spur off this to supply a switch under the cupboards for the lights. There will then be - main ring in, main ring out, spur (to lights) on the feed in, and then the hob on the fused switched side. Is this ok.
Also what cable should i use to connect the lights (2.5mm from the spur to the switch, then transformer joined to the switch, then whats best to connect to the lights).
Sorry if anything is confusing that just me
BTW lights are 5x 20w L/V downlighters with 105w transformer.
