Can I turn an airbrick into a catflap?
10 Oct 2012
Sussex
Sorry, I know there have been previous posts about catflaps in walls but this is a new twist......I have an airbrick in the outer cavity with a concrete tunnel from the inside to the outside, so in theory all I would have to do is knock out the gridwork within the airbrick and fit a catflap. But is the airbrick likely to be loadbearing in anyway and would I need to fit a lintle?
This is driving me somewhat insane so if anyone could shed any light that would be great!
Your wall won't fall down even if you remove the whole airbrick.
I believe cats can technically get through a hole no bigger than their head but will he actually be happy to crawl through such a slim opening on a regular basis? ie if he was being chased he may get though but would he be prepared to otherwise? Why not just core drill a suitably sized hole through?
I'm lucky that its one of the square airbricks c220mm x 220mm so sounds like an easy ish job (hopefully!). thanks for your reply
As freddie says the air brick isn't load bearing in the way you're thinking. What do you have on the inside, a plastic grill type vent cover?
Bet there'll be quite a draft through it by the time you've made it into the cat's front door :D
Wooo-hoo. Done and siliconed. Not bad for a girl! Thanks for all the help!
PS - less draughty now as it was just an open hole on the inside and wide brick gid on the outside so a bit less draughty which is a bonus. Cat won't go near the damn thing yet though. Will have to put her dinner the other side until she either starves or gives in and goes through!!
