can I use 2 X 15mm inlet to shower pump rather than 1 X 22mm
3 May 2010
Aberdeenshire
I am fitting a new 3.3 bar pump to a new 8" rainfall shower.
The pump recommends 22mm inlets but I have the use of two separate 15mm cold and two separate 15mm hot. would it be an advantage to T them together rather than running new 22mm pipe?
One is from the old shower and the other from a bath that has been removed, both are independent feeds from the hot and cold tanks.
