I have an existing cooker circuit with a cooker point which is run in 6mm cable and connected to a 32A MCB. I am having a new kitchen and therefore new oven and hob.
The oven i am planning to have is fitted with a plug and therefore I do not need the cooker point for the oven but I was planning on getting an Induction hob which has a FLC rating of 7200w.
will the existing cooker circuit be able to handle the hob or should I get it rewired in 10mm with a 40A MCB?
The cooker point has a socket at the moment but I do not need this so could get it changed for one without.
Obviously I would rather not have it rewired but if I need to do it I would get this done before the kitchen fitter comes.
Some more info, the 6mm cable from the consumer unit to cooker point is approx 8m and most of this is in a plasterboard to floorboard ceiling void, only 2-3m is under plaster in galvanised chanelling.
I would be grateful for any advice.
