Can i use glass mosaic tiles behind a gas hob????
10 Apr 2012
Yorkshire
I am wanting to create a splash back for the gas hob I have in the kitchen. I have decided to go with using glass mosaic tiles as a cheaper and nicer looking compare to one huge 1200mm huge splash back.
Before I undergo this task does anyone know if these types of tiles are fit for the purpose or are they likely to crack under the heat from the hob. Also if it is possible what tools and materials am I likely to need so that the tiles stay put and the grout does not crack and discolour.
Many Thanks in advance.
Mandy :D
yep they are suitable, no issues with heat.
If you are doing it yourself then have a look at the 'basics' sticky post at the top of this forum
