- Joined
- 24 Nov 2004
- Messages
- 431
- Reaction score
- 5
- Country
Ive been asked to install a small CCTV system in a harbour authority's building. Nothing special, all 13A plug-in ELV stuff.
I suspect that there will be one or more jobsworths who insist that all the stuff is PAT-tested before it crosses the threshold etc.
Can anyone advise what the actual "law of the land" is regarding supplying equipment in this manner?
I believe that:
PAT testing "may or may not" be part of an organisation's proprietary operating procedures.
If it is, then a record of equipment which is PAT-tested must be kept.
(I am interested to know how the practicalities of keeping records of individual IEC cables and other cables without identifiable features works)
Any equipment which does not plug directly into mains MUST NOT be PAT-tested. (this including most consumer electronics which operates via external ELV SM or linear PSU)
is any of the above corrrect?
My own operating procedures exclude any PAT testing based mainly on one bad experience when I PAT tested a PC which caused it to never boot again.
Therefore, I want to be able to plug the gear in, check it is operating OK and then sign over ownership of the gear. (at which point they can PAT test it all they like)
also, as the equipment will be permanently installed, screwed down, using tywraps and conduit, does it still classify as "portable" simply because it is using 13A plug-in connectors?
I believe that:
