I would like to reduce solar heating of the south-side of the house but only during summer (most of the time solar heating is an asset) so I was thinking the easiest thing to do would be to apply some of that solar reflective film to the inside and remove it once summer ends. Obviously performance would be better if the heat was reflected on the other (exterior) side of the glass but I think only the interior ones are made in the removable static cling form instead of the self-adhesive form.
Does anyone here know whether there is any actual basis for rumours of windows cracking or the double-glazing seals being damaged by the heat when you reflect from the inside?
