I have discovered a leaking and fairly corroded micro bore radiator feed pipe.I cannot tighten the connection into the radiator valve anymore than it is. With the end of the micor bore pipe from the floor to the rad valve so corroded is it possible to renew just a short section of the pipe to the rad valve? I don't think I will be able to reach the manifold as the outside hall floor of the room has been tiled! I can open the wooden floor next to the radiator and can see that the pipe is in good condition under the floor. It seems that the leaking rad valve joint has been the cause of the corroded pipe.
Thanks in anticipation
