My walls are made from hollow concrete blocks with a wall thickness of around 15mm. All the original sockets are single gang in 16mm boxes surface mounted on the block. I would like to change these to doubles.
Is there a way around chasing deeper for double boxes, or are converta sockets the best way to do this.
The other problem is that the cables are surface mount with plastic capping. The plaster is a very thin skim over this and is cracking in several places. Would it stand up better if it was replaced with metal capping and re plastered?
Any advice would be appreciated.
