Hi, i own a flat in a converted 1873 railway house. The walls are made of solid brick and are built with the smaller surface of the bricks, making both the internal and external wall surface. The outside has a solid render on them, possibly as old as the building itself, its been scored to look like large blocks. I'm currently experiencing really bad mould problems. I have recently had my chimney re capped and flaunched as it was leaking bad. Gutters unblocked and cracks in the render sealed. Since all this was done the problem has got worse, inline with the weather. I noticed when it rained, the worse internal effected areas were glistening wet outside, and darker. The exterior walls haven't really been seale painted since 1972. Could the walls be letting to much water in and its wicking into the interior walls? Next doors roof is knackered and potentially be a cause, and there is a little damage to the lower walls nothing excessive and hard to imagine it being rising damp. I have surveyor coming out friday as i need to get to the bottom of it. The render doesn't look blown and looks as tight to the walls as ever, are there any sealers that can be used in cold weather, to offer short term protection until next summer? Any ideas or advice would be most appreciated. The damp problems have arisen over the past 12 months, thanks Darren[/b]
