Can somebody explain in simple terms what I need to do for my door?
12 Mar 2019
Right, I have footings up to DPC level:
(Link to image: https://i.imgur.com/8QNI0Y4.jpg)
Rightly or wrongly, I didn't take into account the door because we hadn't fully decided on the internal layout so it's simple two leafs of brick, 100mm cavity all the way round.
Now I'm having real trouble understanding the detail of what I need to do?
So, imagine I'm 5, what do I need to do / what are my options in the area where I position my door? (Which is likely to be the furtherst away wall in the pic)?
Haven't done the oversite yet, so still plenty of scope to change things etc.
I was thinking of using a former with cavity closer for the window, is there an equivalent for doors?
Eh?
What are you actually asking about 'the door'? Are you on about the door opening in the new work?
If you’re having a screed:
Leave as it is, pour your slab, then take out the inner skin bricks where the door is and screed up to the outer skin adding the perimeter insulation
If your finished floor is the slab:
Keep the outer skin as it is, take out the inner skin bricks (top 3 courses) where the door is, add returns from inner to outer skin, do your hardcore, insulation, slab etc, slab extending to outer skin at door.
OK. Whaddya wanna know?
Literally everything! I see Notch has commented on my other thread, so I will review that - but I obviously want to put a door in, but I'm not at all grasping what I do with the cavity, the oversite, floor level etc. I dunno why, I just can't visualise it at the minute.
Right, cool - I'm definitely going to screed it. So I move my inner skin bricks, put in a cavity closer that can take screed (I noticed Kingspan mentioned this, with a minimum depth of 65mm which makes sense) and just straight up go over it? How do I fully support it?
Main thing for the minute is that I can crack on as I thought - I'd seen some references to your second method and was starting to worry a bit.
Well its good news! You have bricks on the inner leaf.
We always leave room (75mm+) for a floor screed so that you can carefully marry the floors in later on. Working from FFL down;
75mm screed
Polythene layer
100mm Celotex insulation.
100mm Floor slab
1200g polythene DPM
25-50mm snad blinding
100mm minimum compacted hard core.
Build the extension complete with door opening (minimum 3 brick from the corner) then remove the top course of bricks in the door opening, line the trough with DPM and screed right into the door opening.
EDITED: beaten by 23VC doh!
You're all absolute stars! (+notch on the other thread) Wouldn't stand a chance taking on this project without this forum.
Right, far happier now though I'm still a bit unclear on how I screed the gap without it all going wrong?
PS:
The insulation can either be positioned under the concrete slab or under the screed. Our default setting is under the slab unless otherwise requested.
PS:
I wonder how that effects thermal efficiency, since it increases thermal mass.
Ive done it both ways, but due to doing underfloor heating so often tend to go over the concrete slab with insulation
What sre you actually building and are you getting building regulations approval :?:
