Hi All
Can someone advise me on a wireless camera security system please ?
I would like 3 + cameras min 1tb hard drive and be able to view on Alexa / TV and mobile phone
I can get power and ethernet to each camera very easy but to run cables direct to the hardrive will be a problem for 1 camera as i want it in the garden i have ethernet in the garage
If you can get ethernet (LAN) cable to each camera and to a router, you do not need them cabling direct to the 'hardrive' (I assume server). The data can go via your network, assuming one cable from the router goes to the server.
