Hi all,
Starting to think about altering my plumbing to accommodate the new extension.
Our main water feed comes into the water meter and we have a combi boiler.
The water meter will be moved, the outlet of it I assume goes to the combi, is there a second pipe from the water meter that supplies the cold to all the taps/basins/baths etc. Or does that cold feed come from the boiler?
The hot water I assume is just a feed out from the boiler to each tap/basin/bath etc. Then stops at the last one or does it have a return to the combi?
How are the radiators generally plumbed, I know there's 2 pipes 1 to the trv the other to the lock shield, do these just run onto the next radiators in sequence until you get to the last one then stop or do they also return back to the combi from the last radiator?
Chris
Chris
