My neighbour is selling his house, price agreed, surveys done, no problems. Due to complete in a week or so. Out of the blue a building inspector called walked in and demanded that the owner knock holes in the plasterboard cladding on an RSJ.
This beam was installed when the wall between the front room and dining room was knocked through by a reputable builder seven years ago.
The beam is double skin clad in plaster board which is mounted on wooden noggins forced into the web of the RSJ and held in with the usual 'interferance' fit.
The inspector told my neighbour that the joist must be stripped, the noggins must be bolted to the joist with Halco bolts, re-inspected, re-clad, and re-inspected.
Charged him £60 and said you're not selling the house until it's done and you've got the certificate to prove it.
He's livid (nearly decked the BI) the purchaser is livid, and no-one seems to know why the inspector called.
Can they retrospectively demand this change, because most of the houses in the country would be 'illegal' if this was the case.
I'm concerned because I've had similar (and other) work done over the years that was perfectly acceptable at the time but now would contravene building regs.
Also what rights of entry do BIs have?
The house is a terraced, over 100 years old with no other problems, passed the structural surveys OK with no works required.
A couple of other builders my neighbour asked both said this was a new one on them and to tell the BI (bleeding idiot) to eff off.
Any thoughts . . .
Any thoughts . . .
