Someone Asked me for a rough quide how much for this.
I canno do it due to the certs required.
As I dont personally do this work I have no idea of cost, but simply ask COULD it be more than £500 .
That will be sufficient for them to decide.
I would say due to the testing etc, it possibly would, but I dont know
They only wanted the cooker supply installed , but the mains was such a state it really needs a new board etc to do so safely.
Three bedroom house with TN-S supply
There is no parking costs, or nothing like that.
1, Supply and wire to point for new oven/hob unit, load unknown assume one switch 45amp max, no socket.
oven/hob to be Fitted by kitchen fitters
Aprox 4 met run surface wired
2, remove 8 way and 4 way fuseboxes and fit 12 way minimum cu (wylex hager or mem or similar).
Wiring appears to be twin and earth
3 All mcb's and rcd's fitted so ALL circuits conform as required to 17th if any different to 16th.
*new cooker
*existing shower 45amp
*two seperate garage supplys
*two lighting, up 6a /down 6a
*two rings, up 32a/ down 32a
*aprox four unknown circuits (some power)
supply appears to be TN-S
4 fit earth block , earth gas meter aprox 2 met, earth water aprox 3 met
5 Replace metre tails (aprox two metres) and fit 2 pole isolator if necessary
Owner is concerned about breaking meter seal, so whatever involved to get board to reseal.
6 carry out any essential work needed , and any essential bonding required to allow the work to be carried out.
Possibly no supp bonding to one bathroom.
7 Test as required and provide relevant paperwork
Thanks in advance for any replys
*new cooker
