Hi
I woke up this morning to find my overflow leaking from my cold water tank (after the hot waater had come for the morning). I've adjusted the ball valve & it's stopped but I've got a lingering doubt.
At the bottom of the cold water tank there's an outlet down into the hot tank in the airing cupboard. The outlet to this from the cold tank is warm & the water in the cold tank immediately by the outlet is also warm.
Is that normal or is it somehow possible that the warm water is coming back into the cold water tank causing it to fill up from the bottom?
Any help would be much appreciated. Thanks
