Hello,
Ive been offered some 150w Metal Halide fittings. If they are too bright for the job, can I replace them with 70w tubes or is the ballest specifically for each wattage lamp?
The ballasts are designed to work with specific lamps. At best they won't work at all, at worst they will burn out quickly. Off the top of my head, 150W lamps are slightly longer so will not fit anyway.
