in my bathroom i have pullcord switch which switches both the light on and the fan (in parallel)
i wish to remove the wiring. the pullcord switch has the lighting ring going into it. and then a wire going to the light
i am replacing with rcb mains through 3a switched fuse outside bathroom which then goes to light and again the fan in parallel
how do i remove the switch? do i need to connect things together. if not do i just put the cable in terminal block and cover with electrical tape?
thanks for any help
thanks for any help
