Hello
My candy cd112 fills with water, it sprays some water and stops, then again and again repeats the same cycle spray-off-spray-off !!! when reset manually, it drains the water ok.... grrrr its only 2 months old!
SYMPTOMS are
*Any program does the same thing in a cycle
*I start it in reset, then any program (eg ECO), i can hear water
coming inside for 1 minuto aprox
*then starts a neverending cycle, paddles turns something, water pulls
under pressure but stops again and again
*When I RESET it fully drains the water inside.
I want to know if you are in knowledge of a very common problem in the
design of the attached circuit board. In fact this board and its
problems, are present in my CANDY CD112 dishwasher machine.
Attached is the image of the board , it says:
ETII
41008104 T 76
130729 R1 40 28/04
just answer me something please!!!! I need to fix it, can you tell me
if it needs complete replacement of the board? because I can't find
candy parts in here.!
[/url][/img]
SYMPTOMS are
ETII
41008104 T 76
130729 R1 40 28/04
