I have a tiny leak on my washing machine.
It isn't when it's filling,,,, or emptying - that was the first place I looked. Inlet seals etc fine
I saw a drip coming from around the sump hose, close to where it comes out of the drum.
I want to take it off to check it over, but am worried that it might be stuck to the drum, with a special adhesive, or fitting.
I have disconnected the other pipes: one to the filter/outlet pump, and the one that goes up to a thinner pipe between the side panel & main drum - I can't see where that goes.
1/ Is this just push fit to the sump/drum ?
2/ Am I right in calling it a Sump hose ?
3/ Where does the smaller pipe go up the side of the drum ?
4/ Who is a reasonable supplier for these items ?
5/ Is there a common 'leak' place on this model ?
Any other help or advice appreciated.
Baz
Baz
