cannon cambridge double oven grill spark
1 Jul 2011
Lanarkshire
Hi ive a Cambridge double oven s1 .
All top burners and both double ovens work fine.
But the grill wont ignite, it will light when match at it so its getting gas.
Theres no spark jumping between the elecroids.
Will it b the actual spark bit or the module.
Has anyone fixed one of these.
Also the bottom oven when lit , all the sparkers keep sparking, some times it stops for a few mins before doing it again other times its fine. Any ideas how this is
Any help as allways is appreciate
Alex
Bump. Anyone any ideas if it's spark modual or what to check. If sparkers knacked wouldI get voltage between the eelecttoids ?
Can you physically either swop a couple of the electrodes with each other, or the connections at the spark generator ie swop the grill to a different outlet. Obviously it will not light the correct burner but you should be able to check it is sparking.
did this get fixed?
If you know that the igniter lead won't reach then that means you have been under the top panel - try just switching the lead from the terminal block to another one to see if it then gets a spark?
Not fixed yet. Have manflu so everything on hold lol.
Will report back when I feel better hopefully in few days
